💡Tips:This tutorial also applies to Ai-WV01-32S module
1. Wi-Fi Module ​
▫️Firmware Flashing ​
🔹Preparation Before Flashing ​
🔹Wiring ​
TTL to USB ModuleAiPi-PalChatV1
GNDGND
TXDRXD
RXDTXD
Vo3V3
Anxinke IOT WeChat Mini Program QR Code
🔹Reference Video for Flashing ​
To enter flashing mode for AiPi-PalChatV1, follow these steps:
  1. Press and hold the BOOT button
  2. Restart the power switch
  3. Start flashing
▫️Log Viewing ​
🔹Serial Assistant Download ​
Use the debugging tool to install the serial assistant, as shown below:
alt text
🔹Select Serial Port and Baud Rate ​
  • Select the corresponding COM port
  • Select baud rate: 2000000
As shown below:
alt text
2. Offline Voice Chip ​
v2.x versions of AiPi-PalChatV1 no longer rely on flashing tools to upgrade firmware. You can directly use the firmware of AiPi-PalChatV1.
We have also flashed the offline voice firmware into the main control chip of AiPi-PalChatV1, and it will automatically upgrade the old version of the offline voice firmware.
Firmware Flashing
▫️Preparation Before Flashing ​
▫️Wiring ​
Flashing ToolAiPi-PalChatV1
GNDGND
DPDP
DMDM
VCC5V
▫️Flashing ​
  • (1). First open the flashing software as shown below:
alt text
After connecting the flasher and powering on, the red light stays on, the green light blinks, and when you press the button on the flasher, the green light turns off. At the same time, the device status in the upper computer changes to ONLINE, and the "Verify" and "Upgrade" buttons become active.
As shown below:
alt text
  • (2). Click "Upgrade" to complete the flashing.
