1. WiFi Module ​
▫️Firmware Flashing ​
🔹Preparation Before Flashing ​
  • Flashing software download: Download
  • AiPi-PalChatV2 firmware download
  • TTL to USB tool, if not available: Buy here
  • Serial driver download
🔹Wiring ​
  • V1.0 version wiring
TTL to USB ModuleAiPi-PalChatV2_V1.0
GNDGND
TXDRX
RXDTX
Vo3V3
DTRIO2
RTSEN
Dimension diagram
  • V2.0 version wiring
TTL to USB ModuleAiPi-PalChatV2_V2.0
GNDGND
TXDRX
RXDTX
Vo3V3
DTRIO2
RTSEN
Dimension diagram
▫️Flashing Steps ​
  • Double-click the BLDevCube.exe software, as shown below:
Click to view
alt text
  • Select the BL616/618 chip, as shown below, and click OK:
Click to view
alt text
  • Select the IOT download mode
Select Uart on the right interface
If you use the CP2102 purchased from Ai-Thinker Taobao store, select baud rate 921600. If you have an FT232 chip, you can select 2000000. The development board serial chip is 340C, you can also select 2000000.
Click to view
alt text
  • Enable composite firmware and select the firmware, as shown below:
Click to view
alt text
2. Log Viewing ​
  • Serial Assistant Download ​
    • It is recommended to use Ai-Thinker Combo-AT debugging tool: Download
    • Use the debugging tool to install the serial assistant
alt text
▫️Select Serial Port and Baud Rate ​
  • Select the corresponding COM port
  • Select baud rate: 2000000
3. Offline Voice Chip ​
Version v1.3 and above of AiPi-PalChatV2 no longer relies on flash tools to upgrade the firmware. You can use the AiPiPalChatV2 firmware directly.
We have burned the offline voice firmware into the main controller chip of AiPi-PalChatV2, it will automatically upgrade the old version of offline voice firmware.
Firmware Flashing
▫️Preparation Before Flashing ​
▫️Wiring ​
Flashing ToolAiPi-PalChatV1
GNDGND
DPDP
DMDM
VCC5V
▫️Flashing ​
  • (1). First open the flashing software as shown below:
alt text
After connecting the flasher and powering on, the red light stays on, the green light blinks, and when you press the button on the flasher, the green light turns off. At the same time, the device status in the upper computer changes to ONLINE, and the "Verify" and "Upgrade" buttons become active.
As shown below:
alt text
  • (2). Click "Upgrade" to complete the flashing.
Released under the MIT License. Build Time 2026-11-13 15:47:31
