由 ckdsx.cn 贡献,Ai-Thinker 进行整理
WB2 示例代码入门---外设串口 ​
**#include** <stdio.h>
**#include** <string.h>
**#include** <FreeRTOS.h>
**#include** <task.h>
**#include** <blog.h> //
**#include** "bl_sys.h"
**#include** <cli.h>
**#include** <hosal_uart.h>
**#include** <blog.h>     //include 一遍头文件即可
**void** **TaskUart**(**void** *param)  //新建无返回函数TaskUart
    **uint8_t** data[32]; //定义 数组data
    **int** ret; //定义变量 ret
hosal_uart_dev_t uart_dev_echo = {         .config = {             .uart_id = 0,             .tx_pin = 4, // TXD GPIO             .rx_pin = 3, // RXD GPIO             .cts_pin = 255,             .rts_pin = 255,             .baud_rate = 9600,   //波特率 9600,8,n,1             .data_width = HOSAL_DATA_WIDTH_8BIT,             .parity = HOSAL_NO_PARITY,             .stop_bits = HOSAL_STOP_BITS_1,             .mode = HOSAL_UART_MODE_POLL,         },     };
hosal_uart_dev_t uart_dev_log = {         .config = {             .uart_id = 1,             .tx_pin = 16, // TXD GPIO             .rx_pin = 7,  // RXD GPIO             .cts_pin = 255,             .rts_pin = 255,             .baud_rate = 115200,  //波特率9600,8,n,1             .data_width = HOSAL_DATA_WIDTH_8BIT,             .parity = HOSAL_NO_PARITY,             .stop_bits = HOSAL_STOP_BITS_1,             .mode = HOSAL_UART_MODE_POLL,         },
    /* Uart init device */
    hosal_uart_init(&uart_dev_log);  //初始化串口设备 日志
    hosal_uart_init(&uart_dev_echo); //初始化串口设备 回显
    blog_info("Uart Demo Start");  //日志输出串口示例开始
    **while** (1) //循环
        /* Uart receive poll */ 串口接收
        ret = hosal_uart_receive(&uart_dev_log, data, **sizeof**(data)); //将串口接收到的数据赋值给ret
        **if** (ret > 0) //判断 如果ret大于0
            /* Uart send poll */
            hosal_uart_send(&uart_dev_log, data, ret); //串口输出ret 数据
            blog_info("Get data ");  //日志输出 获得数据
  • @brief main
**void** **main**(**void**) //主函数
    xTaskCreate(TaskUart, "TaskUart", 1024, NULL, 15, NULL); //执行串口任务
代码已添加注释,还有问题请留言! GPIO是对引脚的常规操作方式,点灯等程序都依靠GPIO方式可实现。
