▫️ Overview ​
Ra-12L(HL)
The Ra-12L(HL) is a wireless module designed and developed by Ai-Thinker Technology that integrates Bluetooth Low Energy (BLE), a 2.4GHz proprietary protocol, and LoRa communication. The module adopts the Telink TL3238E1 as its main control chip, which has built-in BLE for short-range communication, and adopts the Semtech SX1262 as its Sub-GHz wireless transceiver chip for ultra-long-range spread spectrum communication.
The Ra-12L(HL) module can be widely used in automatic meter reading, home and building automation, security systems, remote irrigation systems, and other applications.
▫️ Key Features ​
RF Performance ​
  • Theoretical maximum transmit power: 22dBm@Sub-GHz; 10dBm@BLE/2.4GHz
  • Theoretical receiver sensitivity: -148dBm@BW_L = 10.4kHz/SF12 (refer to chip datasheet)
  • Sub-GHz output power (software setting 22dBm):
    • Ra-12L: 21.5dBm typical at 470MHz / 490MHz / 510MHz
    • Ra-12HL: 21.5dBm typical at 868MHz / 905MHz; 21dBm typical at 930MHz
  • Sub-GHz receive sensitivity (BW = 125kHz, SF7, CR4/6):
    • Ra-12L: -124dBm at 470MHz / 490MHz / 510MHz
    • Ra-12HL: -123dBm at 868MHz; -124dBm at 905MHz / 930MHz
  • Sub-GHz harmonic suppression (RBW/VBW = 1MHz/3MHz):
    • Ra-12L: 2nd and 3rd harmonics at 470MHz@22dBm are -40dBm
    • Ra-12HL: 2nd and 3rd harmonics at 868MHz@22dBm are -38dBm
  • BLE output power (software setting 10.5dBm): 9.5dBm typical at 1Mbps / 2Mbps
  • BLE receive sensitivity: -97dBm at 1Mbps; -95dBm at 2Mbps (@30.8% PER)
  • BLE harmonic suppression: 2nd harmonic -40dBm, 3rd harmonic -50dBm at 2402MHz@10dBm
Operating Frequency Bands ​
  • Ra-12L Sub-GHz: 470 – 510MHz
  • Ra-12HL Sub-GHz: 860 – 930MHz
  • BLE/2.4GHz: 2400 – 2483.5MHz
Power Consumption ​
  • Deep-sleep current: ≤1μA
  • Receive current: 9mA@Sub-GHz; 13mA@BLE 1Mbps
  • Transmit current: Ra-12L 97mA@Sub-GHz (22dBm), Ra-12HL 128mA@Sub-GHz (22dBm); 17mA@BLE 1Mbps (10dBm)
Communication and Protocols ​
  • Supports LoRa and (G)FSK modulation
  • Supports spreading factors SF5, SF6, SF7, SF8, SF9, SF10, SF11, and SF12
  • Built-in LoRaWAN protocol stack
  • Complies with the Bluetooth 6.1 standard
  • Supports Bluetooth/2.4GHz RF transceiver for the worldwide 2.4GHz ISM band
  • BLE supports 1Mbps and 2Mbps, and Long Range modes at 125kbps and 500kbps
Physical Characteristics ​
  • Package: SMD-48
  • Module dimensions (L × W × H): 18.00 × 18.00 × 2.60mm
  • Antenna type:
    • Sub-GHz: IPEX Gen 1 connector or castellated antenna optional
    • BLE/2.4GHz: castellated antenna
  • Operating temperature: -40 – 85℃
  • Storage conditions: -40 – 125℃, < 90% RH
Electrical Characteristics ​
  • Supply voltage: 1.8 – 3.7V (typical 3.3V)
  • Supply current: ≥300mA
  • Communication interface: standard UART interface
  • Protection: built-in ESD protection circuit
Default comparison: modules matching "Ra-12L,Ra-12HL"
Ra-12LViewTBD
Ra-12HLViewTBD
3. Firmware Management ​
ModuleFirmware BuildFirmware DescriptionVersionDownload LinkAT Command Reference
Ra-12L-AT standard firmware (CN470)TBDTBDTBD
Ra-12HL-AT standard firmware (EU868)TBDTBDTBD
  • Ra-12L factory firmware: one CN470 AT firmware with LoRaWAN commands and Bluetooth Combo AT commands; Bluetooth can be used to configure LoRaWAN parameters.
  • Ra-12HL factory firmware: one EU868 AT firmware with LoRaWAN commands and Bluetooth Combo AT commands; Bluetooth can be used to configure LoRaWAN parameters.
  • Bluetooth Combo AT command set: TBD
4. Development Guide ​
▫️ Basic Information ​
  • SX1262 datasheet: View
  • TL3238E1 datasheet: TBD
▫️ Development Tutorials ​
Resource TypeLink
Standard LoRaWAN to private serverView
Connect to overseas TTN LoRaWAN serverView
Connect to ChirpStack serverView
▫️ Secondary Development ​
Resource TypeLink
Secondary development source codeTBD
5. FAQ ​
6. Compliance & Testing ​
ModuleReport
Ra-12LTBD
Ra-12HLTBD
ModuleReport
Ra-12LTBD
Ra-12HLTBD
ModuleCertificationLink
Ra-12LFCC, CETBD
Ra-12HLFCC, CETBD
