▫️ Overview
Ai-M64 Series
The Ai-M64 series modules are Wi-Fi 6 & Bluetooth dual-mode modules developed by Ai-Thinker Co.,Ltd., based on the BL616CL chip, supporting Wi-Fi 802.11b/g/n/ax and BLE 5.3 protocols.
The BL616CL chip features a low-power 32-bit RISC-V CPU with a clock speed up to 320 MHz, providing rich interfaces including Audio Codec, USB 2.0, EMAC, Camera, Display (DBI), MJPEG, SDIO 2.0, Sec_Eng, SPI, UART, I2C, I2S, PWM, Timer, GPADC, and more.
Suitable for audio/video multimedia, IoT, mobile devices, smart home, new energy, and related applications.
▫️ Features
- Supports IEEE 802.11 b/g/n/ax protocols
- Supports BLE 5.3, 2 Mbps / 1 Mbps / 500 kbps / 125 kbps
- Supports Wi-Fi/BLE coexistence, dual-mode TDD operation without interference
- Wi-Fi security: WPS/WEP/WPA/WPA2/WPA3
- Supports 20/40 MHz bandwidth, 1T1R, maximum rate 229.4 Mbps
- Full support for OFDMA, TWT, LDPC, STBC, Beamformee, RX diversity — more stable, farther range, and lower power consumption for multi-device concurrency
- Supports LDPC, STBC, Beamformee, DL/UL OFDMA, MU-MIMO, TWT (Target Wake Time), SR (Spatial Reuse), DCM (Dual Carrier Modulation), ER (Extended Range)
- Supports STA, SoftAP, STA+SoftAP, and sniffer modes
- 32-bit RISC-V CPU with FPU, up to 320 MHz
- 2/4/8 MB Flash, 4/8 MB PSRAM, 388 KB SRAM (224 KB OCRAM, 160 KB WRAM, 4 KB HBN RAM), 1 KB eFuse
- Rich peripheral interfaces: USB 2.0, EMAC, Camera, Display (DBI), MJPEG, SDIO 2.0, Sec_Eng, SPI, UART, I2C, I2S, PWM, Timer, GPADC, etc.
- Supports PDS power-down sleep and HBN sleep mode, sleep current in the μA range
- Integrated RF Balun, PA/LNA
- Supports secure boot, firmware encryption & signing, secure debugging, TrustZone, and full hardware cryptography: AES/MD5/SHA/PKA/TRNG
- Supports AES-ECB/CBC/CTR/GMAC/XTS modes
- Universal AT commands for quick deployment
- Supports secondary development, integrated with Windows and Linux development environments
▫️ Selection Table
| Product Image |
| Wireless Protocol |
| Chip |
| Module Flash Size |
| Frequency Band (MHz) |
| Package |
| Dimensions (L×W×H) (mm) |
| Operating Temp Range (℃) |
| Storage Temp Range (℃) |
| Antenna Type |
| Available GPIO Count |
| Min Supply Voltage (V) |
| Max Supply Voltage (V) |
| RX Current (mA) |
| Deep Sleep Current (μA) |
| Certifications |
| Modulation |
2. Datasheets, PCB Footprint, Schematics
| Module | Datasheet | PCB Footprint | Schematic Diagram | Chip Datasheet |
| Ai-M64P-32S | View | Download | - | CN | EN |
| Ai-M64L-12F | View | Download | - | CN | EN |
| Ai-M64P-32S-Kit | View | - | View | - |
| Ai-M64L-12F-Kit | View | - | View | |
| Ai-M64L-32S | View | Download | - | CN | EN |
| Ai-M64L-32S High Temperature Version | View | Download | - | CN | EN |
| Ai-M64L-32S-Kit | View | - | View | - |
- ASCII (.asc) file import into Altium Designer (AD) instructions: Click to Download
3. Firmware Related
▫️ Firmware Download and Debugging
| Module Model | Firmware ID | Firmware Description | Version | Download Link |
| Ai-M64P-32S | ⭐3603 | AT Middleware Standard Firmware | V4.18_P3.0.3 | Click to Download |
| Ai-M64L-12F | ⭐3644 | AT Middleware Standard Firmware | V4.18_P3.0.3 | Click to Download |
Combo-ATFirmware Changelog: Click to View- Firmware Download Tool: Click to Download
- Firmware Flashing Guide: Click to View
4. Development Guide
▫️ Secondary Development Guide
Secondary Development SDK Source Code: Click to View
Secondary Development SDK Setup Tutorial: Click to View
5. FAQ
- Common Questions FAQ: Click to View
6. Test Reports
| Module Model | Test Report |
| Ai-M64P-32S | Click to View |
| Ai-M64L-12F | Click to View |
| Ai-M64L-32S | Click to View |
| Ai-M64L-32S High Temperature Version | Click to View |
7. Certification Related
▫️ Certification
- Series Certification: Click to View
