▫️ Overview ​
Ai-M65 Series
  • The Ai-M65 series modules are Wi-Fi 6 & Bluetooth dual-mode modules developed by Ai-Thinker Co.,Ltd., based on the BL616CL chip, supporting Wi-Fi 802.11b/g/n/ax and BLE 5.3 protocols.
  • The BL616CL chip features a low-power 32-bit RISC-V CPU with a clock speed up to 320 MHz, providing rich interfaces including Audio Codec, USB 2.0, EMAC, Camera, Display (DBI), MJPEG, SDIO 2.0, Sec_Eng, SPI, UART, I2C, I2S, PWM, Timer, GPADC, and more.
  • Suitable for audio/video multimedia, IoT, mobile devices, smart home, new energy, and related applications.
▫️ Features ​
  • Supports IEEE 802.11 b/g/n/ax protocols
  • Supports BLE 5.3, 2 Mbps / 1 Mbps / 500 kbps / 125 kbps
  • Supports Wi-Fi/BLE coexistence, dual-mode TDD operation without interference
  • Wi-Fi security: WPS/WEP/WPA/WPA2/WPA3
  • Supports 20/40 MHz bandwidth, 1T1R, maximum rate 229.4 Mbps
  • Full support for OFDMA, TWT, LDPC, STBC, Beamformee, RX diversity — more stable, farther range, and lower power consumption for multi-device concurrency
  • Supports LDPC, STBC, Beamformee, DL/UL OFDMA, MU-MIMO, TWT (Target Wake Time), SR (Spatial Reuse), DCM (Dual Carrier Modulation), ER (Extended Range)
  • Supports STA, SoftAP, STA+SoftAP, and sniffer modes
  • 32-bit RISC-V CPU with FPU, up to 320 MHz
  • 2/4/8 MB Flash, 4/8 MB PSRAM, 388 KB SRAM (224 KB OCRAM, 160 KB WRAM, 4 KB HBN RAM), 1 KB eFuse
  • Rich peripheral interfaces: USB 2.0, EMAC, Camera, Display (DBI), MJPEG, SDIO 2.0, Sec_Eng, SPI, UART, I2C, I2S, PWM, Timer, GPADC, etc.
  • Supports PDS power-down sleep and HBN sleep mode, sleep current in the μA range
  • Integrated RF Balun, PA/LNA
  • Supports secure boot, firmware encryption & signing, secure debugging, TrustZone, and full hardware cryptography: AES/MD5/SHA/PKA/TRNG
  • Supports AES-ECB/CBC/CTR/GMAC/XTS modes
  • Universal AT commands for quick deployment
  • Supports secondary development, integrated with Windows and Linux development environments
Default comparison: modules matching "Ai-M65"
2. Datasheets, PCB Footprint, Schematics ​
ModuleDatasheetPCB FootprintSchematic DiagramChip Datasheet
Ai-M65S-01---- | -
Ai-M65P-32SView--- | -
Ai-M65L-32S---- | -
Ai-M65S-01-Kit---- | -
Ai-M65P-32S-Kit---- | -
Ai-M65L-32S-Kit---- | -
▫️ Firmware Download and Debugging ​
Module ModelFirmware IDFirmware DescriptionVersionDownload Link
Ai-M65P-32S⭐3603AT Middleware Standard FirmwareV4.18_P3.0.3Click to Download
Ai-M65L-12F⭐3644AT Middleware Standard FirmwareV4.18_P3.0.3Click to Download
4. Development Guide ​
▫️ Secondary Development Guide ​
5. FAQ ​
6. Test Reports ​
Module ModelTest Report
Ai-M65P-32SClick to View
Ai-M65L-12FClick to View
Ai-M65L-32SClick to View
Ai-M65L-32S High Temperature VersionClick to View
▫️ Certification ​
Released under the MIT License. Build Time 2026-10-30 14:31:49
