▫️ Overview ​
Ra-12HS
The Ra-12HS is a wireless module designed and developed by Ai-Thinker Technology that integrates Bluetooth Low Energy (BLE), a 2.4GHz proprietary protocol, and LoRa communication. The module adopts the Telink TL3238E1 as its main control chip, which has built-in BLE for short-range communication, and adopts the Semtech LLCC68 as its Sub-GHz wireless transceiver chip for ultra-long-range spread spectrum communication.
The Ra-12HS module supports Amazon Sidewalk and can be widely used in automatic meter reading, home and building automation, security systems, remote irrigation systems, and other applications.
▫️ Key Features ​
RF Performance ​
  • Theoretical maximum transmit power: 22dBm@Sub-GHz; 10dBm@BLE/2.4GHz
  • Theoretical receiver sensitivity: -129dBm@BW_L = 125kHz/SF9 (refer to chip datasheet)
  • Sub-GHz output power (software setting 22dBm): 21.5dBm typical at 868MHz / 905MHz / 930MHz
  • Sub-GHz receive sensitivity (BW = 125kHz, SF7, CR4/6): -123dBm at 868MHz; -124dBm at 905MHz / 930MHz
  • Sub-GHz harmonic suppression (RBW/VBW = 1MHz/3MHz): 2nd and 3rd harmonics at 868MHz@22dBm are -38dBm
  • BLE output power (software setting 10.5dBm): 9.5dBm typical at 1Mbps / 2Mbps
  • BLE receive sensitivity: -97dBm at 1Mbps; -95dBm at 2Mbps (@30.8% PER)
  • BLE harmonic suppression: 2nd harmonic -40dBm, 3rd harmonic -50dBm at 2402MHz@10dBm
Operating Frequency Bands ​
  • Sub-GHz: 860 – 930MHz
  • BLE/2.4GHz: 2400 – 2483.5MHz
Power Consumption ​
  • Deep-sleep current: ≤1μA
  • Receive current: 9mA@Sub-GHz; 13mA@BLE 1Mbps
  • Transmit current: 128mA@Sub-GHz (22dBm); 17mA@BLE 1Mbps (10dBm)
Communication and Protocols ​
  • Supports LoRa and (G)FSK modulation
  • Supports spreading factors SF5, SF6, SF7, SF8, SF9, SF10, and SF11
  • Complies with the Bluetooth 6.1 standard
  • Supports Bluetooth/2.4GHz RF transceiver for the worldwide 2.4GHz ISM band
  • BLE supports 1Mbps and 2Mbps, and Long Range modes at 125kbps and 500kbps
Physical Characteristics ​
  • Package: SMD-48
  • Module dimensions (L × W × H): 18.00 × 18.00 × 2.60mm
  • Antenna type:
    • Sub-GHz: IPEX Gen 1 connector or castellated antenna optional
    • BLE/2.4GHz: castellated antenna
  • Operating temperature: -40 – 85℃
  • Storage conditions: -40 – 125℃, < 90% RH
Electrical Characteristics ​
  • Supply voltage: 1.8 – 3.7V (typical 3.3V)
  • Supply current: ≥300mA
  • Communication interface: standard UART interface
  • Protection: built-in ESD protection circuit
Default comparison: modules matching "Ra-12HS"
Ra-12HSViewTBD
3. Firmware Management ​
ModuleFirmware BuildFirmware DescriptionVersionDownload LinkAT Command Reference
Ra-12HS-AT firmware (Sidewalk, high band)TBDTBDTBD
  • Factory firmware: supports Sidewalk connection parameter configuration, device connection, uplink/downlink data, and common commands such as version query and serial port configuration; the Bluetooth part follows the Combo AT command set.
  • Bluetooth Combo AT command set: TBD
  • Telink Sidewalk SDK for secondary development: TBD (based on Telink's official GitHub repository)
4. Development Guide ​
▫️ Basic Information ​
  • LLCC68 datasheet: View
  • TL3238E1 datasheet: TBD
▫️ Development Tutorials ​
Resource TypeLink
Sidewalk connection parameter configuration and uplink/downlink AT commandsTBD
Bluetooth Combo AT command setTBD
Amazon account and Sidewalk onboardingTBD
▫️ Secondary Development ​
Resource TypeLink
Secondary development source codeTBD
5. FAQ ​
  • Sidewalk FAQ: TBD
6. Compliance & Testing ​
ModuleReport
Ra-12HSTBD
ModuleReport
Ra-12HSTBD
ModuleCertificationLink
Ra-12HSFCC, SidewalkTBD
