▫️ Key Features ​
Ra-01SCH
  • The Ra-01SCH is a LoRa series module designed and developed by Ai-Thinker Co., Ltd. It is used for ultra-long-range spread spectrum communication, with its RF chip LLCC68 primarily employing the LoRa™ remote modem for strong anti-interference capabilities and minimal current consumption.
▫️ Technical Highlights ​
  • Supports FSK, GFSK, and LoRa® modulation methods.
  • Covers the frequency band of 803MHz to 930MHz.
  • Operates at 3.3V with a maximum output power of +22dBm and a maximum operating current of 120mA.
  • Exhibits low power consumption in receive mode, with a minimum receive current of 4.2mA and a standby current of 0.6mA.
  • High sensitivity: as low as -129dBm.
  • Supports spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11.
  • Compact dual-row stamp-hole SMD package.
  • Uses an SPI interface for half-duplex communication, with CRC and a packet engine supporting up to 256 bytes.
  • Antenna interface is compatible with multiple connection methods such as stamp holes, round holes, and IPEX connectors, supporting more design options.
Default comparison: modules matching "Ra-01SC"
Ra-01SCHViewDownload
3. STM32F103C8T6 HAL-based driver ​
ModuleLink
Ra-01SCHDownload
ModuleCertificateLink
Ra-01SCHCE (RED)View
Ra-01SCHFCCView
To learn more
5. Compliance & Testing ​
