▫️ Key Features ​
Ra-20H
The Ra-20H is an ultra-high-performance RF front-end module designed for IoT, short-range wireless communication, and Industry 4.0 wireless sensor networks, featuring the SEMTECH fourth-generation LoRa Plus™ LR2021 RF chip as its core. Its key advantage lies in an ultra-compact package and extreme RF performance. By optimizing the collaborative design of power amplifier, low-noise amplifier, filter, and peripheral matching network, it achieves high power, low loss, low spurious emissions, and strong anti-interference capability, while meeting mainstream global regulatory certification requirements.
The Ra-20H module supports Sub-GHz and 2.4GHz ISM bands. It features three key capabilities: ultra-long-range transmission, high-speed data throughput, and global single-SKU adaptability.
▫️ Technical Highlights ​
RF Performance ​
  • Transmit power: measured maximum transmit power of 21.5dBm@Sub-GHz, 12dBm@2.4GHz
  • Power flatness: ≤ ±0.5dBm. Stable full-band and full-power transmission and the power level is software-adjustable in multiple steps.
Receiver sensitivity: ​
  • Sub-GHz: up to -147dBm@BWLORA = 31kHz/SF12/CR4/5 (refer to chip datasheet); measured -122.5dBm@BWLORA = 400kHz/SF7/CR4/5
  • 2.4GHz: up to -137.5dBm@BWLORA = 200kHz/SF12/CR4/5 (refer to chip datasheet); measured -120dBm@BWLORA = 400kHz/SF7/CR4/5
  • Frequency offset tolerance: ±33% BW, far exceeding the previous generation’s ±25% BW. High-precision frequency stability can be achieved without a TCXO.
  • Harmonic suppression: 905MHz@22dBm 2nd and 3rd harmonics ≤ -40dBm, 2450MHz@12dBm 2nd and 3rd harmonics ≤ -40dBm, with sufficient margin to pass CE, FCC and other regulations.
  • Operating Bands
  • Low-frequency band: default 850–930MHz
  • High-frequency band: default 2400–2500MHz
Power Consumption ​
  • Sleep current: ≤ 2μA (average value: 1.65)
  • Receive current: ≤ 6mA
  • Transmit current: Sub-GHz@12dBm 125.8mA; 2.4GHz@12dBm 27mA
Communication and Protocols ​
  • Data rate: FLRC up to 2.6Mbps; LoRa up to 125kbps
  • Supports fourth-generation LoRa IP technology and LR-FHSS
  • Protocol compatibility ( Only the physical layer is supported; the protocol layer needs to be developed by the customer):
    • LoRa / LoRaWAN® at Sub-GHz and 2.4GHz
    • Amazon Sidewalk
    • Bluetooth® LE 5.0 PHY compatible
    • IEEE® 802.15.4™ Thread® and Zigbee™ O-QPSK
    • Sigfox BPSK
    • Wi-SUN FSK
    • Wireless M-BUS (device and collector)
    • Z-Wave®, Z-Wave LR
    • 2-FSK & 4-FSK based protocols
Physical Characteristics ​
  • Package: SMD-20
  • Module dimensions (L × W × H): 20.00 × 16.00 × 3.20mm
  • Antenna type: IPEX MHF 1 connector
  • Operating temperature: -40 – 85℃
  • Storage conditions: -40 – 125℃, < 90% RH
Electrical Characteristics ​
  • Supply voltage: 1.8 – 3.6V (typical value 3.3V)
  • Supply current: > 200mA
  • Communication interface: standard SPI interface
  • Available I/Os: 7 GPIOs are brought out by default
  • Protection: built-in ESD protection circuit
Default comparison: modules matching "Ra-20H"
Ra-20HViewDownload
3. STM32F103C8T6 HAL-based driver ​
ModuleLink
Ra-20HDownload
user manual: View
  • testing
5. FAQ ​
Questions and Solutions View
6. Compliance & Testing ​
Released under the MIT License. Build Time 2026-11-25 18:10:28
