Trace: • UWB module topic
UWB module topic
UWB module topic
Overview
Please poke the full range of modules to purchase:Anxinke official Taobao shop
UWB technology is a wireless carrier communication technology that uses a frequency bandwidth above 1 GHz. It does not use a sinusoidal carrier, but uses nanosecond-level non-sinusoidal narrow pulses to transmit data. Therefore, it occupies a large spectrum. Although wireless communication is used, its data transmission rate can reach hundreds of megabits per second. . Using UWB technology can transmit signals over a very wide bandwidth.
BU01 is an ultra-wideband (UWB) transceiver module based on Decawave's DW1000 design. BU01 integrates antenna, RF circuit, power management and clock circuit. BU01 can be used in two-way ranging or TDOA positioning systems, with positioning accuracy up to 10 cm and supporting data rates up to 6.8 Mbps.
Features
- Simple integration, no RF design required
- Using RTLS infrastructure to expand the communication range
- Support high label density
- Comply with IEEE 802.15.4-2011 UWB standard
- Support 4 channels from 3.5 GHz to 6.5 GHz
- Programmable transmit power
- Power supply 2.8 V to 3.6 V
- Power consumption in sleep mode<1mA
- Support two-way ranging and TDOA
- Support SPI interface
- Data rate 110 kbps, 850 kbps, 6.8 Mbps
BU-01 module documentation summary
Product specification: BU01 module specification BU01_Specification
Product hardware guide: BU01 module guide
Chip manual: DW1000 Chip Manual
Chip data sheet: DW1000 chip data sheet
BU01 positioning algorithm: bphero_uwb_location_sourcecode_v1.1_16mhz.zip Decompression password: aithinker123
BU01 power problems and optimization: DW1000 power problems and optimization guide
BU01 application scenario guidance:
1.W1000 security and security application guidelines
2.DW1000 agricultural application guide
3.DW1000 keyless car system guide
4.DW1000 medical application guide
NodeMCU-BU01 Resource Summary
NodeMCU-BU01 is a development board that integrates Anxinke BU-01 indoor positioning module + MCU. It has an onboard temperature and humidity sensor and provides AT files for easy integration into your project;
Development board features
- 35mm*55mm board 50pin leads to facilitate peripheral function development Micro power interface, convenient for various power supply equipment access
- STM32F103 main control, rich chip resources
- Acceleration sensor, phase measurement, accurate position status information
- Temperature and humidity sensor, measure current temperature and humidity information, no need to connect other temperature and humidity sensors
- Independent buttons and LEDs meet application logic control and status indication
NodeMCU-BU01 specification: NodeMCU-BU01 specification NodeMCU-BU01 specification
NodeMCU-BU01 AT instruction set: BU01 development board AT instruction set
Secondary development tutorial
- NodeMCU-BU01 tutorial: AT is simple to use, positioning the distance between two development boards: https://aithinker.blog.csdn.net/article/details/106493128
- Schematic diagram of NodeMCU-BU01 development board: Schematic Diagram
- NodeMCU-BU01 development board factory firmware AT source code STM32: sdk.zip
Contact us
Email: support@aithinker.com
