Where to Buy: Alibaba
1. Product Introduction
▫️ Overview
ESP8266 Series
  • The ESP8266 series modules are low-power UART-WiFi modules developed by Ai-Thinker Co.,Ltd. based on Espressif's ESP8266EX. They enable rapid prototyping, secondary development, and cloud-connected applications with mobile 3G/4G remote control capabilities.
▫️ Features
  • 802.11 b/g/n
  • Built-in Tensilica L106 ultra-low-power 32-bit micro MCU, supporting 80 MHz and 160 MHz clock speeds, with RTOS support
  • Built-in 10-bit high-precision ADC
  • Built-in TCP/IP protocol stack
  • Built-in TR switch, balun, LNA, power amplifier, and matching network
  • Built-in PLL, voltage regulator, and power management components, with +18 dBm output power in 802.11b mode
  • A-MPDU and A-MSDU aggregation, and 0.4 s guard interval
  • Wi-Fi @ 2.4 GHz, supporting WPA/WPA2 security modes
  • Support for local AT upgrades and cloud OTA upgrades
  • Support for STA/AP/STA+AP operating modes
  • Support for Smart Config (including Android and iOS devices)
  • HSPI, UART, I2C, I2S, IR Remote Control, PWM, GPIO
  • Deep sleep standby current: 20 uA, shutdown current: <5 uA
  • Wake-up, connection, and data packet transmission within 2 ms
  • Standby power consumption: <1.0 mW (DTIM3)
  • Operating temperature range: Refer to specific model specifications for details
2. About Modules
Module NameDatasheetsPCB FootprintSchematic
ESP-01ViewDownload-
ESP-01DViewDownload-
ESP-01SViewDownload-
ESP-01EViewDownload-
ESP-01FViewDownload-
ESP-01MViewDownload-
ESP-07ViewDownload-
ESP-07SViewDownload-
ESP-12EViewDownload-
ESP-12FViewDownload-
ESP-12SViewDownload-
ESP-12S (2MB 8285 Ver.)ViewDownload-
ESP-12LViewDownload-
ESP-13UViewDownload-
ESP-15FViewDownload-
NodeMCU-8266 (1.0)-CP2102--View
NodeMCU-8266 (1.2)-CH340View-View
Module ModelFirmware IDFirmware DescriptionVersionLinkATcommand
ESP8266 Series⭐#1471AT MQTT Standard FWV2.2.0DownloadDownload
ESP8266 Series#0040Standard Firmwarev1.5.4.1DownloadDownload
ESP8266 Series#1470AT MQTT Standard FWV2.2.0DownloadDownload
ESP8266 Series#1030MQTT Standard FirmwareV2.0.0DownloadDownload
▫️ Application Notes
Resource TypeLink
SSL Encryption User ManualEN
Low Power SolutionsEN
Flash R/W Operations GuideEN
FOTA Upgrade GuideEN
Firmware Download ProtocolEN
Technical ReferenceEN
WiFi Channel Selection GuideEN
RTOS SDK Programming GuideEN
▫️ Development Tools
  • SDK Integrated Development Environment (IDE1.5):
    • Download: Baidu Netdisk
    • Access Code: shm3
    • Update Date: 2020.10.16
    • Changelog: Supports ESP8266 NONOS 2.0 & 3.0
  • Firmware Programming Tool: ESP_DOWNLOAD_TOOL
    • Download: Flash Tool
    • Update Date: 2021.11.10
    • Changelog: Supports ESP32/ESP32-S2/ESP32-C3/ESP8266/ESP8285
  • Ai-Thinker Serial Debug Assistant
  • TCP/UDP Network Debug Assistant (PC)
  • TCP/UDP Network Debug Assistant (Android)
  • Serial Drivers (Windows)
  • USB-T1 Serial Drivers (Multi-OS)
  • Ai-Thinker Combo-AT Debugger
  • Series Certificates: View
Released under the MIT License. Build Time 2026-06-05 16:21:50
