GPRS A9/A9G series module topic
A9 is the latest GSM/GPRS module launched by Essence. The cost reduction of the core chip makes the whole solution more cost-effective. It provides information transmission functions such as serial port to GPRS/short message/voice call, which is widely used in the fields of Internet of things/vehicle/electric environment detection.
A9G is a complete quad-band GSM/GPRS+GPRS/GPS module. The cost reduction of the core chip makes the whole solution more cost-effective. It is convenient to apply to various IoT hardware terminal occasions.
Ca-01 is an ultra-small package LTE Cat.1 bis module launched by Essence. It adopts Unigroup’s UIS8910 platform and supports LTE 3GPP Rel.13 technology. It is a 4G full Netcom module that can adapt to different operators and products to ensure Maximum flexibility in product design.
Selection table
Main specifications
A9/A9G Module
- A9/A9G size: 19.2*18.8*2.7mm (±0.2mm)
- Working temperature -20℃+70℃;
- Working voltage 3.8V-4.2V, 4V power supply is recommended;
- Boot voltage>3.8V;
- Low power consumption average current is below 2mA;
- Support GSM/GPRS four frequency bands, including 850, 900, 1800, 1900MHZ;
- GPRS Class 10;
- Sensitivity ←105dB;
- Support voice calls;
- Support SMS;
- GPIO level is at 2.8V;
- Support GPRS data service, maximum data rate, download 85.6Kbps, upload 42.8Kbps;
- Support standard GSM07.07,07.05 AT commands and Ai-Thinker extended commands;
- A9 supports 3 serial ports, one download serial port and one AT command port;
- A9G supports 3 serial ports, one download serial port and one GPS serial port;
- AT commands support standard AT and TCP/IP command ports;
- Support digital audio and analog audio, support HR, FR, EFR, AMR voice coding;
- Support GPS+AGPS (only applicable to A9G);
4G Cat.1 module Ca-01
specification:
- Ca-01 size: 24.0*24.0*2.3mm (±0.2mm)
- Frequency band: LTE-TDD: B34/B38/B39/B40/B41; LTE-FDD: B1/B3/B5/B8;
- Support VoLTE; Support Camera; Support analog voice;
- Working temperature -40℃~+85℃;
- Working voltage 3.3V-4.3V, 3.8V power supply is recommended;
- Power consumption: 20uA@shutdown, 3mA@sleep, typical value;
- Data: LTE-TDD: uplink and downlink ratio 2 [maximum 8Mbps(DL)/maximum 2Mbps(UL)]; uplink and downlink ratio 1[maximum 6Mbps(DL)/maximum 4Mbps(UL)];
- Data: LTE-FDD: Maximum 10Mbps (DL)/ Maximum 5Mbps (UL);
interface:
- 1 USB 2.0 high speed interface (up to 480Mbps)
- 1.8V/3.0V (U) SIM card interface
- 1 NETLIGHT interface (NET_STATUS and NET_MODE)
- 2 analog voice input
- 2 analog voice output
- 3 UART interfaces
- 1 SPI interface
- 1 SPI LCD interface
- 1 SPI Camera interface
- 1 MMC interface
- PWRKEY (active low)
- Support 6*6 array keyboard
- 2 ADC interfaces
- Electrical parameters-Output power: LTE-TDD: Class3(23dBm+1/-3dB); LTE-FDD: Class3(23dBm+-2dB);
- General features: 3GPP E-UTRA Release 13;
- Bandwidth: 1.4/3/5/10/15/20MHz;
- Package: stamp hole + LGA;
- Weight: about 2.6g;
Debugging related
AT command debugging
A9Tracker related functions
(Among A9Tracker related functions, the A9 module uses the base station positioning function, and the A9G module can choose to set the base station positioning function or the GPS positioning function, and upload the current position information to WeChat or app regularly. When positioning indoors, due to GPS signals Too weak, it is recommended to set the base station positioning function. For details, please refer to the following documents)
- A9/A9G 10-minute docking with Gizwits to create your own product tutorial: http://www.jianshu.com/p/e3d86a263be5
Secondary development
- CSDK_Github open source information: Open Source Information
- C_SDK development kit: development kit
- Tool chain CSDTK4.2 download: CSDTK4.2 Extraction code: yc11
Firmware related
- Firmware release: GPRS 固件发布
- GPRS series module upgrade guide: GPRS 系列模组升级指南
- Firmware release: GPS 固件发布
- GPS series module upgrade guide: GPS 系列模组升级指南
Resource summary
Anxinke Information
- User Manual (user_manual): A9/A9G User Manual (A9/A9G hardware design can refer to the A9G development board schematic diagram)
- AT instruction set (at_instruction_set): A9/A9G AT instruction setA9/A9G AT_Command_seriesCa-01AT command set
- STM32 driver for A9/A9G (for reference only): program
- Hardware information (hardware_info): A9/A9G_hardware_infoCA-01 hardware package
- Debugging tool (serial_tool): Serial debugging tool
- FAQ document: 安信可gps_gprs_a9g常见问题faq.pdf
- Precautions for mass production: Precautions for GPRS mass production
- Module certificate: GPRS系列模组证书
Guokewei original factory information
Pudding Series Development Board
Other resources
Contact us
Email: support@aithinker.com
