Introduction Videos
- Master AiPi-UNO-ET485 + LoRaBoard with the UP 主!Remote Temperature and Humidity Monitoring at Your Fingertips!
- Perfect Combination of AiPi-UNO-ET485 Development Board and Light Sensor! Simplify Data Collection!
1. Overview
AiPi-LoRaBoard
- AiPi-LoRaBoard is an expansion board designed for the AiPi-UNO-ET485 development board, featuring the Ra-08 module and a 1.9-inch MIPI-DBI capacitive touchscreen.
- The Ra-08 module operates in the 410MHz~525MHz frequency band and is compatible with LoRa modules such as Ra-01/SC and Ra-02. It comes with a default 433MHz rubber duck antenna (communication distance untested). Replacing with the Ra-08H allows operation in the 803MHz~930MHz band.
- The 1.9-inch screen uses a MIPI-DBI interface with 170*320 pixels and supports capacitive touch.
2. Development Resources
▫️ User Manual
- AiPi-LoRaBoard Usage Guide with AiPi-UNO-ET485: Download
▫️ PCBA Resources
▫️ Factory Firmware
▫️ Source Code
- Ra-08 Source Code: Uploading...
- AiPi-UNO-ET485 Source Code: View
