▫️ Key Features
Ra-09(H)
- The Ra-09(H) module is a LoRaWAN module jointly developed by Ai-Thinker Co., Ltd. and ST. The module uses the STM32WLE5CCU6 chip, with 256 KB Flash, 64 KB SRAM, and a 32-bit Arm® Cortex®-M4 48MHz core. The Ra-09(H) module comes pre-installed with AT firmware, allowing direct use to connect to LoRaWAN gateways.
Ra-09-DTU
- The Ra-09-DTU is an intelligent wireless data communication DTU developed by Shenzhen Ai-Thinker Co., Ltd. using the company's own Ra-09 LoRa module. It utilizes LoRa wireless technology for ultra-long-distance spread spectrum communication.
▫️ Technical Highlights
Excellent anti-interference capability, capable of normal operation in complex interference environments
Minimum receiving sensitivity: -137dBm (SF=12/BW=125KHz)
Maximum transmit power: +21dBm
Operating frequency: (Ra-07/08/09/09-DTU) 410MHz~525MHz (default), (Ra-07H/08H/09H) 803MHz~930MHz (default)
Power supply voltage: 3.3V (Ra-07/08/09/09/07H/08H/09H), 12V (Ra-09-DTU)
Transmit operating current: 107mA (full load power consumption)
Receive operating current: 6mA
| Ra-09 | View | Download |
| Ra-09H | View | Download |
| Ra-09-DTU | View | N/A |
3. Firmware Management
| Module | Firmware Build | Firmware Description | Version | Download Link | AT Command Reference |
| Ra-09 | ★ Build 2298 | CN470 Standard AT Firmware | V1.0.2 | Download | View |
| Ra-09H | ★ Build 3397 | KR920 Standard AT Firmware | V1.0.0 | Download | View |
| Ra-09H | ★ Build 3396 | AS923-2 Standard AT Firmware | V1.0.0 | Download | View |
| Ra-09-DTU | ★ Build 2343 | Standard DTU Firmware | V1.2.0 | Download | N/A |
4. Compliance & Testing
| Module | Report |
| Ra-09 | View |
| Ra-09H | View |
| Module | Report |
| Ra-09-DTU | View |
| Ra-09 | View |
5. Certification Related
| Module | Certificate | Link |
| Ra-09H | CE (RED) | View |
| Ra-09H | FCC | View |
| Ra-09 | CE (RED) | View |
| Ra-09 | FCC | View |
