▫️ Key Features
Ra-03SCH
  • This module is designed for ultra-long-range spread spectrum communication. It employs the LLCC68 RF chip and SEMTECH's LoRa™ modulation technology. The chip features -129 dBm high sensitivity and +22 dBm transmit power, delivering ultra-long-range, highly reliable communication while demonstrating exceptional anti-interference capabilities and low power consumption. LoRa™ technology effectively addresses the challenge of balancing range, anti-interference performance, and power consumption in conventional solutions.
  • It is suitable for widespread applications including automatic meter reading, home and building automation, security systems, remote irrigation systems, and more.
▫️ Technical Highlights
  • Supports FSK, GFSK, and LoRa® modulation methods.
  • Covers the frequency band from 803 MHz to 930 MHz.
  • Operates at 3.3 V with a maximum output power of +22 dBm and a maximum operating current of 140 mA.
  • Exhibits low power consumption in receive mode, with a minimum receive current of 4.2 mA and a standby current of 0.6 mA.
  • High sensitivity: down to -129 dBm.
  • Supports spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11.
  • Compact dual-row stamp-hole SMD package.
  • Utilizes an SPI interface with half-duplex communication, featuring CRC and a packet engine supporting up to 256 bytes.
  • Antenna interface uses half-hole pads for connecting to an external antenna on the main board.
Ra-03SCHViewDownload
MoudlesCertificateLink
Ra-03SCHANATELView
Ra-03SCHCE (RED)View
Ra-03SCHFCC - LoRaWAN ProtocolView
Ra-03SCHFCC - Private ProtocolView
To learn more
4. Compliance & Testing
