▫️ Key Features
RG-02
- The RG-02 is an indoor LoRaWAN gateway that supports Semtech packet forwarders and LoRaWAN base station functions, while being compatible with the standard LoRaWAN protocol. It adopts a mainstream LoRa modulation and demodulation chip solution (SX1302 + 2*1250) and supports 10 programmable parallel demodulation paths.
- The gateway supports WiFi, Ethernet, and 3G/4G cellular network access methods, enabling convenient deployment in various application scenarios. It comes pre-configured with multiple standard LoRaWAN frequency band options, adapting to different countries and regions. Additionally, it supports user-defined frequency bands for building private LoRa networks.
- The RG-02 can communicate with ABP LoRaWAN end nodes without a LoRaWAN server. Its lightweight deployment makes it easy for system integrators to directly connect it to existing IoT applications without the need to set up a LoRaWAN server or use third-party LoRaWAN services.
▫️ Technical Highlights
Web GUI and SSH management via LAN or WiFi.
Emulates 49x LoRa demodulators.
Maximum transmit power of +27 dBm.
Pre-configured with multiple LoRaWAN regional settings and supports custom frequency points:
- High-frequency version (EU868, IN865, RU864, KZ869), low-frequency version (CN470).
Semtech packet forwarder.
Multiple network access methods:
- WiFi IEEE 802.11 b/g/n.
- Ethernet 10/100M.
- Cellular network.
| Module | Specification |
| RG-02(Low-frequency version) | View |
| RG-02(High-frequency version) | View |
3. Guide
- The RG-02 gateway connects to the TTN platform to control multiple LoRaWAN module nodes.:View
- The RG-02 gateway integrates network configuration, enabling MQTT configuration to connect to the network server and facilitating data intercommunication.:View
4. FAQ
- FAQ:LiINK
