Trace: • 4G Cat.1 series module topic
Ca-01 is an ultra-small package LTE Cat.1 bis module launched by Essence. It adopts Unigroup’s UIS8910 platform and supports LTE 3GPP Rel.13 technology. It is a 4G full Netcom module that can adapt to different operators and products to ensure Maximum flexibility in product design.
Purchase link
Main specifications
4G Cat.1 module Ca-01
specification:
- Ca-01 size: 24.0*24.0*2.3mm (±0.2mm)
- Frequency band: LTE-TDD: B34/B38/B39/B40/B41; LTE-FDD: B1/B3/B5/B8;
- Support VoLTE; Support Camera; Support analog voice;
- Working temperature -40℃~+85℃;
- Working voltage 3.3V-4.3V, 3.8V power supply is recommended;
- Power consumption: 20uA@shutdown, 3mA@sleep, typical value;
- Data: LTE-TDD: uplink and downlink ratio 2 [maximum 8Mbps(DL)/maximum 2Mbps(UL)]; uplink and downlink ratio 1[maximum 6Mbps(DL)/maximum 4Mbps(UL)];
- Data: LTE-FDD: Maximum 10Mbps (DL)/ Maximum 5Mbps (UL);
interface:
- 1 USB 2.0 high speed interface (up to 480Mbps)
- 1.8V/3.0V (U) SIM card interface
- 1 NETLIGHT interface (NET_STATUS and NET_MODE)
- 2 analog voice input
- 2 analog voice output
- 3 UART interfaces
- 1 SPI interface
- 1 SPI LCD interface
- 1 SPI Camera interface
- 1 MMC interface
- PWRKEY (active low)
- Support 6*6 array keyboard
- 2 ADC interfaces
- Electrical parameters-Output power: LTE-TDD: Class3(23dBm+1/-3dB); LTE-FDD: Class3(23dBm+-2dB);
- General features: 3GPP E-UTRA Release 13;
- Bandwidth: 1.4/3/5/10/15/20MHz;
- Package: stamp hole + LGA;
- Weight: about 2.6g;
Resource summary
Anxinke Information
- Development board schematic diagram: ca-01开发板原理图纸.pdf
- Hardware design manual: ca-01_模块硬件设计手册.pdf
- AT instruction set (at_instruction_set): Ca-01AT instruction set
- CA-01 routine (for reference only): 连接阿里云stm32例程.zip 连接阿里云at流程说明_一机一密认证方案_.pdf 连接阿里云at流程说明_一机一密认证方案_.pdf
- Hardware information (hardware_info): CA-01 hardware package
- Debugging tool (serial_tool): Serial debugging tool
Other resources
Contact us
Email: support@aithinker.com
