▫️ Overview ​
BU Series
  • BU01 is an Ultra-Wideband (UWB) module designed by Shenzhen Ai-Thinker Co., Ltd. based on Decawave's DW1000 series chips. It integrates an antenna, RF circuit, power management, and clock circuit. BU01 can be used in two-way ranging or TWR positioning systems, achieving a positioning accuracy of up to 10 centimeters and supporting a data rate of up to 6.8 Mbps.
  • BU03 is an Ultra-Wideband (UWB) module designed by Shenzhen Aithinker Technology Co., Ltd. based on Decawave's DW3000 series chips. BU03 integrates an onboard ceramic antenna, RF circuit, and power management. It can be used in two-way ranging, TDOA, or PDOA positioning systems, achieving a positioning accuracy of up to 10 centimeters and supporting a data rate of up to 6.8 Mbps.
  • BU04 is a dual-antenna Ultra-Wideband (UWB) module designed by Shenzhen Aithinker Technology Co., Ltd. based on Decawave's DW3000 series chips. BU04 integrates DW3000 + STM32F103 MCU and supports dual onboard antennas or dual IPEX connectors for external antennas. It can be used in two-way ranging, TDOA, or PDOA positioning systems, achieving a positioning accuracy of up to 10 centimeters and supporting a data rate of up to 6.8 Mbps.
2. Datasheets, PCB Footprint, Schematic ​
Module NameDatasheetPCB FootprintSchematic Diagram
BU01ViewDownload-
BU03ViewDownload-
BU04ViewDownloadView Diagram
NodeMCU-BU01-KitView--
BU03-KitView-View Diagram
BU04-KitView-View Diagram
3. Firmware and Development Guide ​
🔹 BU01 ​
Resource TypeLink
Development Board Factory Firmware AT Command SetView
Development Board Positioning Test DistanceClick to View
Development Board Factory Firmware STM32 Source CodeClick to download
🔹 BU03 ​
Module ModelFirmware IDFirmware DescriptionVersionDownload LinkAT Command ReferenceHost Software
BU032717Standard AT FirmwareV1.0.0DownloadView Docs• TWR Algorithm
• PDOA Algorithm
BU033718Standard AT FirmwareV1.0.1DownloadView Docs• TWR Algorithm
• PDOA Algorithm
Resource TypeLink
FAQClick to View
Development Materials SummaryClick to download
Test GuideClick to View
Accuracy Calibration Coefficient Calculation TemplateClick to download
Secondary Development Online Guide DocumentClick to View
Secondary Development SDKClick to download ; Extraction code: oh0s
🔹 BU04 ​
BU042717Standard AT FirmwareV1.0.0DownloadView Docs• TWR Algorithm
• PDOA Algorithm
BU043718Standard AT FirmwareV1.0.1DownloadView Docs• TWR Algorithm
• PDOA Algorithm
Resource TypeLink
FAQClick to View
Test Guide (Brief)Click to View
Test Instructions Blog PostClick to View
4. Test Report ​
▫️ Power Consumption Test Report ​
ModuleTest Report
BU01View
BU03View
BU04View
▫️ Certification Certificate ​
