Trace: • GPS module topic
GPS module topic
GPS module topic
Overview
Please poke the full range of modules to purchase:Anxinke official Taobao shop
BG01/BG01-T and BG02/BG02-T are modules independently developed by Boantong Technology based on the GK9501 navigation SoC chip, featuring low power consumption and small size. Support BDS/GPS/GLONASS/GALILEO/QZSS/SBAS multi-mode satellite positioning, with high-performance ceramic antenna, widely used in car navigation, smart wear, drones and other smart devices, can upgrade multi-mode positioning function.
GP-01 and GP-02 are modules independently developed by Anxinke Technology based on the latest generation of self-developed radio frequency baseband integrated navigation SoC chips. They have the characteristics of low power consumption and small size, and support BDS+GPS dual mode for the first time. Joint positioning is the best choice for terminal equipment to replace a single GPS module or add Beidou positioning function. It can support customers to upgrade the multi-mode positioning function in smart devices such as tracker, OBD, positioning bracelet, campus card and so on.
Features of BG series GPS module
Support BDS/GPS/GLONASS/GALILEO/QZSS/SBAS multi-system joint positioning and single system independent positioning
Support D-GNSS differential positioning, A-GNSS assisted positioning, ephemeris prediction, DR integrated navigation application, fastest data update rate 10Hz
32-bit application processor, maximum frequency 133MHz, support frequency dynamic adjustment
Support PPS output
Peripheral interface: UART
BG series GPS module selection table
Model | BG01``New | BG02 New | BG01-T New | BG02-T New'' | |||
Size(mm) | 16.2*12.2 | 10.3*9.9 | 26*25 | 21*18 |
Antenna | External antenna | External antenna | Ceramic antenna | Ceramic antenna |
Certification | RoHS | RoHS | RoHS | RoHS |
Features of GP series GPS module
Small size 12mm*16mm(GP-01); 9.7mm*10.1mm(GP-02).
The chip adopts 55nm process, QFN 40pin package, size 5mm*5mm*0.8mm
18mA ultra-low power consumption
Integrated RF, baseband and Flash
Support BDS/GPS joint positioning
Support A-GPS, A-BDS
On-chip LNA: 1.5dB noise figure
Power management: CPU automatically sleeps and automatically reduces power consumption during operation; supports 2.7-3.6V power supply, recommended 3.3V; RTC and backup circuit power can be as low as 1.5V.
Rich peripheral interfaces: 2 independent UART interfaces; 2 independent SPI interfaces; 1 I2C interface. The module is powered on and reads data directly from the serial port.
Working temperature: -40°C~85°C.
Resource summary
User manual and development documentation: GPS 文档中心
Development example: GPS 示例
Development tools: GPS测试工具
GP-02 hardware packageGP-02 package download
GP-01 hardware packageGP-01 package download
BG series GPS module hardware package library hardware package library
BG series GPS module firmwarefirmware download
Other resources
Contact us
Email: support@aithinker.com
