language:
Ai-Thinker Technology
A9Tracker app instructions for use
A9Tracker download: APK:A9Tracker
Two-dimensional code making software download and instructions: Download QR code generator, enter in the text area and send AT commands through the serial debugging assistant The character string obtained by AT+GIZQRCODE (note that there is no line break), click Generate to get the QR code.
Note, the work that needs to be done before using the APP: Please make sure that the SIM card is inserted in the device and the antenna part is intact. The entire device is working properly. Module part operation instructions → After the module is powered on for the first time, perform a two-step operation. 1. Use AT+GIZQRCODE to read the two-dimensional code string to make a two-dimensional code. 2. Use AT+GIZTRACKER=1,0,10,1 (specific parameter meaning, refer to AT+GIZTRACKER instruction analysis) command to connect to the server. Note that this command will be automatically saved, and subsequent module power-on will automatically run this command and automatically upload positioning information. If you need to close it, please use AT+GIZTRACKER=0 to close;
AT+GIZTRACKER=< on/off >,[server],[upload interval],[use LBS],[pk],[ps]
n/off value: 0/1. When this parameter is 0, it is closed, and set to 1 for automatic upload serve Select server: 0 is the Anxinke server; 1 is a custom server (PK and PS parameters must be attached to the first use, and these two parameters will be saved after the connection is successful) up in the time interval of uploading data (s), the default value is 0 (not uploading) Use LBS value: 0/1. Set to 1 to use LBS, and set to 0 to not use LBS. The key and secret of the pk ps product. These are used when creating the product by yourself. For details, see 9/A9G 10-minute docking with Gizwits Cloud to create your own product: http://www.jianshu.com/p/e3d86a263be5
1. Get A9Tracker app
You can search for A9Tracker through 360 mobile assistant. You can also click to download directly at the top of this tutorial.
2. Registration
Find the A9Tracker application on your mobile desktop and open it, find the text “Register a new user” in the displayed interface and click to jump to the register new user interface; enter the correct mobile phone number in the first input box and click on the right Get verification code“ button to get the A9Tracker registration verification code, wait for the verification code SMS and enter the 6-digit verification code obtained into the second input box; set your login password in the third input box, and click the small on the right The eye icon shows or hides the password you set; after setting and confirming your password, click the “register now” button to register; at this point, you have completed the A9Tracker APP user registration process.
3. Login
Find the A9Tracker application on your mobile desktop and open it, enter the mobile phone number you registered in the second step in the first input box on the displayed interface; enter the mobile number you registered in the second step in the second input box The password corresponding to the mobile phone number, click the small eye icon on the right to check whether the password is entered correctly or hide the password you entered; after confirming the mobile number and password, click the “login button” to log in; at this point, you have completed the A9Tracker APP user login process .
4. Anonymous login
Find the A9Tracker application on your mobile desktop and open it, and find the “Skip»” button in the displayed interface to log in anonymously. This step is only required to complete the anonymous log in process.
5. Retrieve the password
Find the A9Tracker application on your phone desktop and open it, find the text “Forgot your password?” in the displayed interface and click to jump to the reset password interface, and enter your registered phone number in the first input box on the interface And click the “Get Verification Code” button on the right to get the SMS verification code for resetting the password; wait for the arrival of the SMS and enter the 6-digit verification code obtained into the second input box; in the third input box Enter the new password you need to set, and click the small eye icon on the right to view the entered password or hide the password; after confirming the new password, click the “reset password” button; at this point, you have completed the process of retrieving the password.
6. Binding devices
After the login is successful, jump to the My Device interface (A9Tracker will apply for the permission to locate the mobile phone, please click Allow at this time, otherwise it will affect the subsequent operations). If you haven’t bound any device yet, click the “•••” icon in the upper right corner and click the “Scan for binding device” option in the pop-up drop-down menu (A9Tracker asks you for permission to use the camera, click agree, or it will affect subsequent operations), Or click the middle part of the page to automatically call the camera to scan the code (note that the first time you use the APP, click here, it will remind you that there is an error in calling the camera. This is because there is no permission, so it is recommended that you click the upper right corner when you use it for the first time “•••” icon, follow the prompts to give permissions). After successfully obtaining the camera permission, it will jump to the QR code scanning interface. At this time, place the QR code corresponding to your A9G module (to obtain the QR code, please refer to the beginning of the tutorial on this page) behind the phone camera to make a two-dimensional The image formed by the code is in the scanning box of the APP interface, waiting for the result of the scanning process; after the binding is successful, pull down the page to refresh, and the bound device appears; Here, the process of binding the device is completed.
7. equipment monitoring
After binding the device, you need to insert the SIM card (China Mobile) into the device with the built-in A9 module and power it on so that the module can connect to the Internet; after powering on the bound device and connecting to the Internet, the device will be offline Transition to online status, it will be displayed in the “Online Devices” column of the list of “My Devices” interface of the APP; clicking on any online device will jump to the device monitoring interface (you need to grant positioning permission); In the device monitoring interface, you can locate the device and use the APP to perform a series of operations. For detailed functional operations, refer to Item 8. At this point, you have completed the introduction to APP operation.
8. APP function
1. Locate the current location of the phone and display it in the center on the map → click the first one of the vertical buttons floating in the upper right corner of the map
2. Locate the current position of the A9 module and display it in the center on the map → click the second one of the vertical buttons floating in the upper right corner of the map
3. Switch to normal map/satellite map → click the third one of the vertical buttons floating in the upper right corner of the map
4. More map operations
  4.1 Zoom the map -> Pinch and adjust with two fingers, or click the "+"/"-" floating in the vertical button at the bottom right corner of the map
  4.2 Map Rotation -> Place two fingers on the map and swipe clockwise/counterclockwise around the midpoint of the two-finger contacts, click the compass icon to reset to true north
5. Add a fence to the device
  5.1 Recording fence
      Click the "•••" icon in the upper right corner of the device monitoring interface to pop up a drop-down menu and click the "Record Fence" option, and then click on three points or more in different locations on the map to display the polygon fence.
  5.2 Save the fence
      After recording your electronic fence, click the "•••" icon in the upper right corner of the device monitoring interface to pop up a drop-down menu and click the "Save Fence" option
  5.3 Clear mark
      After recording your electronic fence, click the "•••" icon in the upper right corner of the device monitoring interface to pop up a drop-down menu and click the "Clear Mark" option
  5.4 Clear shape
      To clear the fence on the map, click the "•••" icon in the upper right corner of the device monitoring interface to pop up the drop-down menu and click the "Clear Shape" option
  5.5 Read fence
      Get the fence saved locally, click the "•••" icon in the upper right corner of the device monitoring interface to pop up a drop-down menu and click the "Read Fence" option
6 More explanation After reading the local fence and successfully displaying it on the map, when the location reported by the device is outside the fence, the APP will send the current location of the device to the notification bar of the phone (note that you need to keep the page on the monitoring interface in the application First page).
