Trace: • ESP32-Audio-kit
ESP32-Audio-kit
ESP32-Audio-kit
What do you need
- 1 ESP32-Audio-kit development board
- 1 micro USB cable
- 1 PC with Windows, Linux or Mac OS system
Overview
Please poke the full range of modules to purchase:Anxinke official Taobao shop
ESP32-Audio-kit is a small audio development board developed by Ai-Thinker based on the ESP32-A1S module. Most audio peripherals are distributed on both sides of the development board. It supports TF card, headphone output, two microphone inputs and two speaker outputs. . It is convenient for developers to develop quickly.
Function description
earphone port (earphone)
Insert the 3.5mm headphone jack to support left and right channel output.
left channel of speaker/right channel of speaker
Support the maximum output of 4Ω3W speaker output, while supporting dual-channel output.
SD card
Maximum support 64G SD card read and write
Key (KEY)
Support 6-channel key input, default access method below the factory
NAME | IO |
KEY1 | IO36 |
KEY2 | IO13 |
KEY3 | IO19 |
KEY4 | IO23 |
KEY5 | IO18 |
KEY6 | IO5 |
You can modify the circuit button AD input.
Microphone
Two analog microphones, each as audio input
Headset Input (LINEIN)
Support headset microphone input
Lithium battery (battery)
Support 3.7V lithium battery input
Power input (POWER)
Maximum support 5V2A power input, support simultaneous lithium battery charging.
Serial port (UART)
Support micro usb serial port input and output, maximum support 921600 baud rate
Download button (BOOT)
Please pull down when downloading. Since IO0 provides the codec clock, please do not press it when the program is running normally, otherwise it will affect the codec work
(The factory contains default firmware, if you need to burn the default firmware, you can click the compressed package at the bottom of the page to download)
Reset button (EN)
Press this button to reset the system
Power supply mode
1.Micro USB port 5V/2A
2. Lithium battery powered
Data download
SDK download
ESP-ADF API documentation
Schematic download
Example
Please refer to the Ai-example example in ESP-ADF for specific usage tutorials
