uwb [2020/07/17 02:46] aithinker_fae [NodeMCU-BU01资源汇总] |
uwb [2020/09/15 13:34] aithinker_fae [BU-01模组文档汇总] |
行 29: | 行 29: | ||
===== BU-01模组文档汇总 ===== | ===== BU-01模组文档汇总 ===== | ||
- | 产品规格书:{{ :uwb:docs:bu01_product_specification_zh_v1.0.pdf | BU-01 模组规格书}} {{ :uwb:docs:bu01_product_specification_en_v1.0.pdf | BU-01_Specification}} | + | 产品规格书:{{ :uwb:docs:bu01_product_specification_zh_v1.0.pdf | BU01 模组规格书}} {{ :uwb:docs:bu01_product_specification_en_v1.0.pdf | BU01_Specification}} |
行 38: | 行 38: | ||
芯片数据手册:{{ :uwb:docs:dwm1000-datasheet-1.pdf | DW1000 芯片数据手册}} | 芯片数据手册:{{ :uwb:docs:dwm1000-datasheet-1.pdf | DW1000 芯片数据手册}} | ||
- | BU01定位算法:{{ :uwb:files:BPHero_UWB_Location_SourceCode_V1.1_16MHz.zip |}} | + | BU01定位算法:{{ :uwb:files:BPHero_UWB_Location_SourceCode_V1.1_16MHz.zip |}} 解压密码:aithinker123 |
BU01功耗问题及优化:{{ :uwb:docs:DW1000 功耗问题及优化.pdf |DW1000功耗问题及优化指导手册}} | BU01功耗问题及优化:{{ :uwb:docs:DW1000 功耗问题及优化.pdf |DW1000功耗问题及优化指导手册}} |
