lorawan [2020/05/22 05:48] aithinker_fae [资源汇总] |
lorawan [2024/03/18 08:58] aithinker_fae [Ra-09/Ra-09H 规格书] |
- | Ra-07/Ra-07H 用户手册:{{ :lora:asr6501-asr6502-lora-sw-user-guide-v4.2.pdf|Ra-07/Ra-07H_用户手册}} | + | Ra-09 模组规格书:{{ :ra-09_v1.0.0_specification_cn_20230905.pdf | 中文}} {{ :ra-09_v1.0.0_specification_en_20230905.pdf | EN}} |
行 90: | 行 127: | ||
