lorawan [2020/05/22 05:47] |
lorawan [2024/03/18 08:21] |
- | LoRa私有网关:{{ :lora:rg-01_规格书.pdf|RG-01_产品规格书}}{{ :llora:rg-01_specification.pdf| RG-01 Product Specification}} | + | |
- | Ra-07/Ra-07H 用户手册:{{ :lora:asr6501-asr6502-lora-sw-user-guide-v4.2.pdf|Ra-07/Ra-07H_用户手册}} | ||
- | Ra-07/Ra-07H 硬件设计指南:{{ :lora:21_asr6501_2_硬件设计应用指南_190328.pdf|Ra-07/Ra-07H 硬件设计指南}} | + | ===== Ra-07/Ra-07H 规格书 ===== |
行 90: | 行 125: | ||
