lorawan [2020/05/22 05:40] aithinker_fae [资源汇总] |
lorawan [2024/03/18 08:28] aithinker_fae [Ra-09/Ra-09H 规格书] |
- | Ra-07/Ra-07H 用户手册:{{ :lora:asr6501-asr6502-lora-sw-user-guide-v4.2.pdf|Ra-07/Ra-07H_用户手册}} | + | Ra-09 模组规格书:{{ |中文}} {{ | EN}} |
- | Ra-07H Q&A手册:{{ :lora:asr6501_asr6502_q_a_v0.2.pdf|Ra-07H_Q&A手册}} | + | Ra-07开发板规格书:{{ :ra-07-kit_v1.0_specification_20210312.pdf |}} |
- | 源码:[[https://github.com/Ai-Thinker-Open/alios-asr-lora|Ra-07H开源代码]] | + | Ra-07-Kit/Ra-07H-Kit原理图:{{ ::ra-07-kit-v1.0-schemetic.pdf |}} |
行 89: | 行 127: | ||
