lorawan [2020/05/22 05:37] |
lorawan [2024/03/28 03:31] |
- | ====== LoRaWAN 解决方案 ====== | + | ===== 安信可各类ESP8266模组规格书汇总(Product Specification)===== |
- | + | - {{ :esp8266:docs:esp-01_product_specification_zh.pdf | ESP-01 产品规格书}} | |
- | + | - {{ :esp8266:docs:esp-01_product_specification_en.pdf | ESP-01 Product Specification}} | |
- | <WRAP center round tip 50%>**全系列模组购买请戳:**[[http://shop.ai-thinker.com|安信可官方淘宝店]]</WRAP> | + | - {{ :esp8266:esp-01d_v1.1规格书-gn20210602.pdf | ESP-01D 产品规格书}} |
- | + | - {{ :esp8266:docs:esp-01s_product_specification_zh_v1.0.pdf | ESP-01S 产品规格书}} | |
- | ===== 概述 ===== | + | - {{ :esp8266:docs:esp-01e_product_specification_zh_v1.0.pdf | ESP-01E 产品规格书}} |
- | + | - {{ :esp-01e_product_specification_en.pdf | ESP-01E Product Specification}} | |
- | ---- | + | - {{ :esp8266:docs:esp-01f_product_specification_zh_v1.0.pdf |ESP-01F 产品规格书}} |
- | + | - {{ :esp8266:docs:esp-01f_product_specification_en.pdf | ESP-01F Product Specification}} | |
- | 安信可 Ra-07H模块是一款支持远距离通信、超低功耗、高灵敏度、高性价比的LoRaWAN模块。模组的芯片ASR6501集成了LoRa无线电收发器,LoRa调制解调器和32位RISC MCU。 MCU使用ARM Cortex M0 +内核,工作频率为48MHz。 ASR6501的工作频率范围可支持150MHz~960MHz的连续覆盖;支持LoRa 调制方式和(G)FSK调制方式。 | + | - {{ :esp8266:docs:esp-01f_规格书_宽温版_.pdf| ESP-01F(宽温版) 产品规格书}} |
- | + | - {{ :esp8266:docs:esp-01m_product_specification_zh_v1.0.pdf | ESP-01M 产品规格书}} | |
- | \\ | + | - {{ :esp8266:docs:esp-01m_product_specification_en.pdf | ESP-01M Product Specification}} |
- | + | - {{ :esp8266:docs:esp-07_product_specification_zh.pdf | ESP-07 产品规格书}} | |
- | =====应用领域===== | + | - {{ :esp8266:docs:esp-07_product_specification_en.pdf | ESP-07 Product Specification}} |
- | + | - {{ :esp8266:docs:esp-07s_product_specification_zh_v1.0.pdf | ESP-07S 产品规格书}} | |
- | ---- | + | - {{ :esp8266:docs:esp-07s_product_specification_en.pdf | ESP-07S Product Specification}} |
- | + | - {{ :esp8266:docs:esp-07s_规格书_宽温版_.pdf | ESP-07S(宽温版) 产品规格书}} | |
- | 可广泛应用于各种物联网场合: | + | - {{ :esp8266:docs:esp-07s_high_temperature_datasheet.pdf | ESP-07S wide temperature version Product Specification}} |
- | * 自动抄表\\ | + | - {{ :esp8266:docs:esp12e_datasheet.pdf | ESP-12E Product Specification}} |
- | * 家庭楼宇自动化\\ | + | - {{ :esp8266:docs:esp-12f_规格书.pdf | ESP-12F 产品规格书}} |
- | * 安防系统\\ | + | - {{ :esp8266:docs:esp-12f_product_specification_en.pdf | ESP-12F Product Specification}} |
- | * 远程灌溉系统 | + | - {{ :esp8266:docs:esp-12s_product_specification_zh_v1.0.pdf | ESP-12S 产品规格书}} |
- | \\ | + | - {{ :esp8266:docs:esp-12s_product_specification_en.pdf | ESP-12S Product Specification}} |
- | + | - {{ :esp8266:docs:esp-12s_wide_temperature_version_product_specification_zh_v1.0.pdf | ESP-12S (宽温版)产品规格书}} | |
- | =====特性===== | + | - {{ :esp8266:docs:esp-12s_8285_2m_flash-宽温版_规格书.pdf | ESP-12S (2M |
- | * 具备超强的抗干扰能力,能够在复杂干扰环境下正常工作\\ | + | |
- | * 最小接收灵敏度:-137dBm (SF=12/BW=125KHz) \\ | + | |
- | * 最大发射功率+21dBm\\ | + | |
- | *工作频率:803MHz~930MHz(默认)\\ | + | |
- | * 电源电压输入:3.3V\\ | + | |
- | * 发射工作电流:107mA (满载功耗) \\ | + | |
- | * 接收工作电流:6mA \\ | + | |
- | * 睡眠电流:3uA\\ | + | |
- | ===== 资源汇总 ===== | + | |
- | LoRaWAN规格书: | + | |
- | {{ :lora:ra-07h_data_sheet_cn.pdf|Ra-07H_产品规格书}} {{ :lora:ra-07h_data_sheet_en.pdf | Ra-07H Product Specification}} | + | |
- | {{ :lora:ra-07_data_sheet_cn.pdf|Ra-07_产品规格书}} {{ :lora:ra-07_data_sheet_en.pdf | Ra-07 Product Specification}} | + | |
- | Ra-07H AT指令手册:{{ :lora:asr6501-asr6502-at-commands-introduction-v4.3.pdf|Ra-07H_AT指令手册}} | + | |
- | Ra-07H 开发指导手册及开发环境搭建:{{ :lora:asr6501-asr6502应用开发demo说明.pdf|Ra-07H_开发指导手册}}{{ :lora:asr6501-asr6502应用开发环境搭建指南.pdf|Ra-07H 开发环境搭建手册}} | + | |
- | Ra-07H 用户手册:{{ :lora:asr6501-asr6502-lora-sw-user-guide-v4.2.pdf|Ra-07H_用户手册}} | + | |
- | Ra-07H 硬件设计指南:{{ :lora:21_asr6501_2_硬件设计应用指南_190328.pdf|Ra-07H 硬件设计指南}} | + | |
- | Ra-07H API使用手册:{{ :lora:asr6501-asr6502芯片api使用手册.pdf|Ra-07H_API使用手册}} | + | |
- | Ra-07H RF调试指南:{{ :lora:LoRa 模块RF调试指南.pdf|Ra-07H RF调试指南}} | + | |
- | Ra-07H Q&A手册:{{ :lora:asr6501_asr6502_q_a_v0.2.pdf|Ra-07H_Q&A手册}} | + | |
- | 源码:[[https://github.com/Ai-Thinker-Open/alios-asr-lora|Ra-07H开源代码]] | + | |
- | LoRaWAN节点:[[http://wiki.ai-thinker.com/sx127x-052|SX127x-052]] | + | |
- | LoRaWAN网关:[[http://wiki.ai-thinker.com/rhf2s008p4g|RHF2S008P4G]] | + | |
- | [[http://wiki.ai-thinker.com/lorawanuse|LoRaWAN系统简单使用教程]] | + | |
- | {{ :lora:lorawan_faq问题.pdf |LoRaWAN_FAQ常见问题}} | + | |
- | =====其它资源===== | + | |
- | [[http://shop.ai-thinker.com|安信可官方淘宝店铺]] | + | |
- | [[http://bbs.ai-thinker.com|安信可官方论坛]] | + | |
- | =====联系我们===== | + | |
- | 商务:18022036575(微信同号)\\ | + | |
- | 邮箱:[[support@aithinker.com|support@aithinker.com]] | + |
