lorawan [2020/04/28 02:56] aithinker_fae [资源汇总] |
lorawan [2024/03/18 08:28] aithinker_fae [Ra-09/Ra-09H 规格书] |
- | Ra-07H AT指令手册:{{ :lora:asr6501-asr6502-at-commands-introduction-v4.3.pdf|Ra-07H_AT指令手册}} | + | Ra-08H-Kit 开发板规格书:{{ :ra-08h_kit_v1.2.0_specification.pdf |中文}} {{ :lora:docs:ra-08h_kit_v1.1.0_specification_-20220308.pdf | EN}} |
- | Ra-07H 开发指导手册及开发环境搭建:{{ :lora:asr6501-asr6502应用开发demo说明.pdf|Ra-07H_开发指导手册}}{{ :lora:asr6501-asr6502应用开发环境搭建指南.pdf|Ra-07H 开发环境搭建手册}} | + | 芯片规格书:{{ ::asr6601_datasheet_v1.4.1.pdf | 中文 }} |
- | Ra-07H 用户手册:{{ :lora:asr6501-asr6502-lora-sw-user-guide-v4.2.pdf|Ra-07H_用户手册}} | + | ===== Ra-09/Ra-09H 规格书 ===== |
- | Ra-07H 硬件设计指南:{{ :lora:21_asr6501_2_硬件设计应用指南_190328.pdf|Ra-07H 硬件设计指南}} | + | Ra-09 模组规格书:{{ |中文}} {{ | EN}} |
- | Ra-07H API使用手册:{{ :lora:asr6501-asr6502芯片api使用手册.pdf|Ra-07H_API使用手册}} | + | Ra-09H 模组规格书:{{ :ra-09h_v1.0.0_specification-cn.pdf | 中文}} {{ :ra-09h_v1.0.0_specification-en.pdf | EN}} |
- | Ra-07H RF调试指南:{{ :lora:LoRa 模块RF调试指南.pdf|Ra-07H RF调试指南}} | + | Ra-07规格书: {{ :lora:docs:ra-07_data_sheet_cn.pdf |Ra-07_产品规格书}} {{ :ra-07_data_sheet_en.pdf |Ra-07_Product_Specification}} |
- | Ra-07H Q&A手册:{{ :lora:asr6501_asr6502_q_a_v0.2.pdf|Ra-07H_Q&A手册}} | + | Ra-07H规格书:{{ :lora:ra-07h_data_sheet_cn.pdf|Ra-07H_产品规格书}} {{ :lora:ra-07h_data_sheet_en.pdf | Ra-07H Product Specification}} |
- | 源码:[[https://github.com/Ai-Thinker-Open/alios-asr-lora|Ra-07H开源代码]] | + | Ra-07开发板规格书:{{ :ra-07-kit_v1.0_specification_20210312.pdf |}} |
- | LoRaWAN节点:[[http://wiki.ai-thinker.com/sx127x-052|SX127x-052]] | + | Ra-07-Kit/Ra-07H-Kit原理图:{{ ::ra-07-kit-v1.0-schemetic.pdf |}} |
- | LoRaWAN网关:[[http://wiki.ai-thinker.com/rhf2s008p4g|RHF2S008P4G]] | ||
- | [[http://wiki.ai-thinker.com/lorawanuse|LoRaWAN系统简单使用教程]] | + | ====== 二 出厂固件和使用指导 ====== |
+ | ===== Ra-08/Ra-08H 出厂固件和使用指导 ===== | ||
- | \\ | + | ===== Ra-08/Ra-08H 应用开发 ===== |
行 87: | 行 127: | ||
