两侧同时换到之前的修订记录 前一修订版 后一修订版 | 前一修订版 上一修订版 两侧同时换到之后的修订记录 | ||
2.4g [2020/06/22 08:16] 127.0.0.1 外部编辑 |
2.4g [2023/06/21 11:52] aithinker_fae [二次开发文档资料] |
- | ====== 2.4G 模组专题 ====== | + | ====== 2.4G 模组系列 ====== |
行 17: | 行 17: | ||
- | ^产品型号 ^芯片型号 ^通信接口 ^最大功率(mW) ^参考距离(m) ^供电电压(V) ^空中速率(bps) ^天线形式 ^封装形式 ^尺寸大小(mm)^ | + | {{ :2.4g:spec:2.4G_02.jpg?nolink&1000 |}} |
- | |NF-01-S |Si24R1 |SPI |5 |240 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | + | |
- | |NF-01-N |nRF24L01+ |SPI |1 |100 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | + | |
- | |NF-02-PA |nRF24L01+ |SPI |100 |1000 |1.9~3.6 |250K~2M |SMA |直插 |40.8*15.3 | | + | |
- | |NF-02-PE |nRF24L01+ |SPI |100 |1000 |1.9~3.6 |250K~2M |IPEX |直插 |40.8*15.3 | | + | |
- | |NF-03 |Si24R1 |SPI |5 |240 |1.9~3.6 |250K~2M |板载天线 |贴片 |18.0*12.0 | | + | |
- | |NF-04 |BK2425 |SPI |2.5 |120 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | + | |
- | |NF-04-MI |BK2425 |SPI |2.5 |120 |1.9~3.6 |250K~2M |板载天线 |贴片 |18.0*12.0 | | + | |
- | ====== 资源汇总 ====== | + | ====== 规格书 ====== |
- | ---- | + | NF-01-S模组规格书:{{ :2.4g:docs:nf-01-s_2_.pdf |中文}} {{ ::nf-01-s_specification_en.pdf |EN}} |
- | 2.4G模组选型手册及规格书:[[2.4G:docs|2.4G文档中心]] | + | NF-01-N模组规格书:{{ :2.4g:docs:spec:nf-01-n_20180926.pdf | 中文}} {{ ::nf-01-n_specification_en.pdf|EN}} |
- | 芯片手册: | + | NF-02-SM模组规格书:{{ :2.4g:docs:spec:nf-02-sm_20180926.pdf | 中文}} |
- | NF-01-N、NF-02-PA、NF-02-PE:{{ :2.4g:docs:nrf24l01p_product_specification_1_0.pdf | nRF24L01+.pdf}} | + | NF-03模组规格书:{{ :2.4g:docs:spec:nf-03_20180926.pdf | 中文 }} {{ ::nf-03_specification_en.pdf |EN}} |
- | NF-01-S、NF-03:{{ :2.4g:docs:si24r1.pdf | Si24R1.pdf}} | + | NF-04模组规格书:{{ :2.4g:docs:spec:nf-04_20180926.pdf | 中文}} |
- | NF-04、NF-04-MI:{{ :2.4g:docs:bk2425_datasheet_v1.3.pdf | BK2425.pdf}} | + | NF-04-MI模组规格书:{{ :2.4g:docs:spec:nf-04_-mi_20180926.pdf | 中文}} {{ ::nf-04-mi_specification_en.pdf |EN}} |
- | 安信可2.4G测试板相关资料:{{ :2.4g:boards:24l01_test_v1.1.rar | 原理图及PCB相关文档}}、{{ :2.4g:boards:stc-isp-15xx-v6.85.zip | 烧录工具}}、{{ :2.4g:boards:nrf24l01_.7z | 测试程序}} | + | NF-05模组规格书:{{ :nf-05_v1.1.0_specification.pdf |中文}} {{ :esp32:examples:Updata_NF-05 Module Specification V1.1.0.pdf | EN }} |
- | 2.4G模组demo程序:{{ :2.4g:boards:nrf24l01_.7z | nRF24L01+}}、{{ :2.4g:boards:si24r1.7z | Si24R1}}、{{ :2.4g:boards:bk2425.7z | BK2425}} | + | NF-05-S模组规格书:{{ :nf-05-s_v1.1.0_specification.pdf |中文}} {{ :esp32:examples:Updata_NF-05-S Module Specification V1.1.0.pdf | EN }} |
- | 2.4G常见问题:{{2.4g:docs:安信可2.4g系列模组常见问题.pdf | 2.4G FAQ文档}} | + | NF-02-PA(基于 nRF24L01+ 芯片)模组规格书:{{ :2.4g:docs:spec:nf-02-pa_20180926.pdf | 点击下载}} |
- | \\ | + | NF-02-PE(基于 nRF24L01+ 芯片)模组规格书:{{ :2.4g:docs:spec:nf-02-pe_20180926.pdf | 点击下载}} |
- | =====其它资源===== | + | NF-02-PA(基于 Si24R1芯片)模组规格书:{{ :2.4g:docs:nf-02-pa_si24r1_模组规格书sph20210603.pdf | 点击下载}} |
- | ---- | + | NF-02-PE(基于 Si24R1芯片)模组规格书:{{ :2.4g:docs:nf-02-pe(si24r1)模组规格书sph20210603.pdf | 点击下载}} |
+ | ======== 二次开发文档资料 ======== | ||
+ | 安信可2.4G测试板相关资料:{{ :2401_test_board_v1.1.pdf | 原理图}}、{{ :2.4g:boards:stc-isp-15xx-v6.85.zip | 烧录工具}}、{{ :2.4g:boards:nrf24l01_.7z | 测试程序}} | ||
+ | 在售的2.4G模组通用demo驱动程序:{{ :2.4g:boards:nrf24l01_.7z | nRF24L01+}}、{{ :2.4g:boards:si24r1.7z | Si24R1}}、{{ :2.4g:boards:bk2425.7z | BK2425}}、{{ :ci24r1.zip |ci24r1}} | ||
+ | 2.4G常见问题:{{2.4g:docs:安信可2.4g系列模组常见问题.pdf | 2.4G FAQ文档}} | ||
+ | ======== 原厂资料 ======== | ||
+ | 模组NF-01-N、NF-02-PA、NF-02-PE的原厂芯片手册下载:{{ :2.4g:docs:nrf24l01p_product_specification_1_0.pdf | nRF24L01+.pdf}} | ||
+ | 模组NF-01-S、NF-03的原厂芯片手册下载:{{ :2.4g:docs:si24r1.pdf | Si24R1.pdf}} | ||
+ | 模组NF-04、NF-04-MI的原厂芯片手册下载:{{ :2.4g:docs:bk2425_datasheet_v1.3.pdf | BK2425.pdf}} | ||
+ | 模组NF-05、NF-05-S的原厂芯片手册下载:{{ :ci24r1_datasheet_v1.4.pdf |Ci24R1.pdf}} | ||
