2.4g [2019/12/25 07:21] aithinker_fae [资源汇总] |
2.4g [2020/12/24 07:25] aithinker_fae [选型表] |
行 17: | 行 17: | ||
- | ^产品型号 ^芯片型号 ^通信接口 ^最大功率(mW) ^参考距离(m) ^供电电压(V) ^空中速率(bps) ^天线形式 ^封装形式 ^尺寸大小(mm)^ | + | | **产品型号** | **芯片型号** | **通信接口** | **最大功率(mW) ** | **参考距离(m)** | **供电电压(V) ** | **空中速率(bps) ** | **天线形式 ** | **封装形式 ** | **尺寸大小(mm)^ **| |
|NF-01-S |Si24R1 |SPI |5 |240 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | |NF-01-S |Si24R1 |SPI |5 |240 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | ||
|NF-01-N |nRF24L01+ |SPI |1 |100 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | |NF-01-N |nRF24L01+ |SPI |1 |100 |1.9~3.6 |250K~2M |板载天线 |直插 |28.6*15.3 | | ||
- | |NF-02-SM |Si24R1 |SPI |5 |300 |1.9~3.6 |250K~2M |SMA |直插 |29.0*15.3 | | ||
|NF-02-PA |nRF24L01+ |SPI |100 |1000 |1.9~3.6 |250K~2M |SMA |直插 |40.8*15.3 | | |NF-02-PA |nRF24L01+ |SPI |100 |1000 |1.9~3.6 |250K~2M |SMA |直插 |40.8*15.3 | | ||
|NF-02-PE |nRF24L01+ |SPI |100 |1000 |1.9~3.6 |250K~2M |IPEX |直插 |40.8*15.3 | | |NF-02-PE |nRF24L01+ |SPI |100 |1000 |1.9~3.6 |250K~2M |IPEX |直插 |40.8*15.3 | | ||
行 40: | 行 39: | ||
NF-01-N、NF-02-PA、NF-02-PE:{{ :2.4g:docs:nrf24l01p_product_specification_1_0.pdf | nRF24L01+.pdf}} | NF-01-N、NF-02-PA、NF-02-PE:{{ :2.4g:docs:nrf24l01p_product_specification_1_0.pdf | nRF24L01+.pdf}} | ||
- | NF-01-S、NF-02-SM、NF-03:{{ :2.4g:docs:si24r1.pdf | Si24R1.pdf}} | + | NF-01-S、NF-03:{{ :2.4g:docs:si24r1.pdf | Si24R1.pdf}} |
NF-04、NF-04-MI:{{ :2.4g:docs:bk2425_datasheet_v1.3.pdf | BK2425.pdf}} | NF-04、NF-04-MI:{{ :2.4g:docs:bk2425_datasheet_v1.3.pdf | BK2425.pdf}} | ||
行 47: | 行 46: | ||
2.4G模组demo程序:{{ :2.4g:boards:nrf24l01_.7z | nRF24L01+}}、{{ :2.4g:boards:si24r1.7z | Si24R1}}、{{ :2.4g:boards:bk2425.7z | BK2425}} | 2.4G模组demo程序:{{ :2.4g:boards:nrf24l01_.7z | nRF24L01+}}、{{ :2.4g:boards:si24r1.7z | Si24R1}}、{{ :2.4g:boards:bk2425.7z | BK2425}} | ||
+ | 2.4G常见问题:{{2.4g:docs:安信可2.4g系列模组常见问题.pdf | 2.4G FAQ文档}} | ||
