Trace: • GPS series module upgrade guide • 4G Cat.1 series module topic • AiPi-Knob • Pudding Series Development Board • Overview
Overview
Overview
Please poke the full range of modules to purchase:Anxinke official Taobao shop
RHF76-052 is a LoRAWAN modem, developed and designed by Anxinke Technology. It has a built-in LoRaWAN protocol stack and supports AT command set. It has the advantages of low power consumption, low cost, wide coverage, and low complexity. It is more suitable for Collect information on large-scale “things”. LoRa network solves the problems of high cost of traditional GPRS network and multiple deployment of gateways. With LoRa technology, enterprises can build their own networks, completely avoiding the traffic charges of operators, and greatly reducing the cost of networking;
Features
Use serial communication to control the module by sending AT commands
Support dual band 433/470MHz and 868/915MHz
Built-in LoRaWAN protocol stack, supporting China CLAA protocol
Support EU868/US915/AU915/Japan 902-928MHz LBT function
Up to 72 upstream channels (64 normal channels with a bandwidth of 125kHz and 8 channels with a bandwidth of 500kHz)
Support CLASS A and CLASS C, Class B will be launched later
Support APB and OTAA to join the network
Support custom data rate
Support communication with full duplex LoRaWAN gateway
Support LoRa point-to-point communication
Support RSSI detection
Current as low as 1.45uA in sleep mode
Upgrade firmware via serial port
Application field
Metering and billing
Smart home and building automation
Intelligent traffic intelligent parking lot
Wireless alarm and security system
Industrial monitoring and energy supply regulation
Remote irrigation and environmental monitoring
M2M application
