uwb [2020/07/08 09:11] aithinker_fae [BU-01模组文档汇总] |
uwb [2020/07/27 09:28] aithinker_fae [BU-01模组文档汇总] |
行 38: | 行 38: | ||
芯片数据手册:{{ :uwb:docs:dwm1000-datasheet-1.pdf | DW1000 芯片数据手册}} | 芯片数据手册:{{ :uwb:docs:dwm1000-datasheet-1.pdf | DW1000 芯片数据手册}} | ||
- | BU01定位算法:{{ :uwb:files:BPHero_UWB_Location_SourceCode_V1.1_16MHz.zip |}} | + | BU01定位算法:{{ :uwb:files:BPHero_UWB_Location_SourceCode_V1.1_16MHz.zip |}} 解压密码:aithinker123 |
BU01功耗问题及优化:{{ :uwb:docs:DW1000 功耗问题及优化.pdf |DW1000功耗问题及优化指导手册}} | BU01功耗问题及优化:{{ :uwb:docs:DW1000 功耗问题及优化.pdf |DW1000功耗问题及优化指导手册}} | ||
行 88: | 行 88: | ||
* NodeMCU-BU01教程:AT简单使用,定位2个开发板的距离:[[https://aithinker.blog.csdn.net/article/details/106493128|]] | * NodeMCU-BU01教程:AT简单使用,定位2个开发板的距离:[[https://aithinker.blog.csdn.net/article/details/106493128|]] | ||
+ | * NodeMCU-BU01开发板原理图:{{ :uwb-db-v1.1原理图.pdf |原理图}} | ||
